Model No. A1367 / 8, 16, 32, or 64 GB capacity
Why is my iPod touch freaking out?
My ipod touch is making a ''little box" around every app I touch and i have to double-tap for the app to start. It also won't let me scroll down on anything(ex. settings, safari pages, etc.)Another thing it has done is rarely let me get to my second page of apps. My ipod also shouts out everything I do so if I'm entering my passcode it shouts out the numbers of it, and a more annoying one is when my screen is locked...
In wrap up it has...
  1. 1: A little box around each thing I touch...
  2. 2: I have to double tap to get to the thing I want to get...
  3. 3: No scrolling down...
  4. 4: Rare access to my second page of apps...
  5. 5: Shouts out everything I type...
Score 18
11 Comments
Rachel, did you try to restore it under iTunes?
by
it does all that stuff to mine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
by
@kennedy, and what have you done about it? Have you tried the solution that I proposed in my original answer?
by
it does it to me 2
by
guys same case and im crying please help....how do i even scroll down in the settings to click accessibility?
by
Show 6 more comments
Add a comment
Chosen Solution
Rachel is it possible that you have the accessibility options on. It does sound like it, at least most of your problems. Check out this link and see if that is familiar.http://www.apple.com/accessibility/itune... and here is how to manage it. http://support.apple.com/kb/ht3577 but these are just my 2cents and I may be way off:) good luck
Score 15
18 Comments:
I love you. oldturkey03, I was literally about to cry because I didn't know how to fix it. Until the part telling me how to scroll so I could get to accessibility. So THANK YOU. :)
by
it worked thanks alot..big help..
by
U r welcome :-) good luck.
by
OMG thank you sooo much! such a relif i thought i would have to take my ipod back O.O
by
same!!!! its really anoyinng
by
Show 13 more comments
Add a comment
triple tap the home button or go to settings >general>accessibility and TURN OFF voice over
Score 4
4 Comments:
That is what the links in the original answers are saying.....:-)
by
How do you fix it
by
How do you fix it now m hole screen turned black
by
See Bryan's easy answer. This works, was easy to understand and is quick. I followed the apple support link into confusion and dismay, yet Bryan's took 10 seconds and a few double clicks. Cheers mate!
by
Add a comment
Rachel this is the voiceover in accessibility, you might have turned it on. I suggest you go to settings, then general, then accessibility, from there you would see the voice over, tap it. Then turn it off.
By the way, for you to do this, you need to scroll down which you cannot, so use three fingers simultaneously to scroll. I hope this solves your problem :)
Score 3
3 Comments:
Thank you so so so much!! I was going crazy trying to figure this out today! Your post saved me some grey hair!
by
i had the same thing happen to me and the 3 finger thing actually works so thanks
by
Brilliant thanks for the info. My daughter had the same thing. I thought we were going to have to replace it. It took a couple of tries to get the three finger scroll thing to work but it did. Working perfectly now. Thank you.
by
Add a comment
Go to settings, and click on genaral-accesibility-Turn off the voice over!
Score 2
1 Comment:
how do i click accessibility if I cant scroll down? How do I scroll down?
by
Add a comment
Sync It To iTunes && Click Configure Universal Access..
Then Where It Says Speak Auto Text Click That Box Until It DOES NOT Have A Box Anymore. Then Click Apply. If Apply Isn't Optional Then I Guess Press Sync.
Hope I Helped.
I Had The Same Problem.
Score 1
Add a comment
go to settings if not able to slide over to it use three fingers to swipe go to general three fingers scroll down to accessibility and turn voice over off by double tapping
Add a comment
Add your answer
Rachel will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 76
All Time: 59,928
